CruzKing
Predator "dyno Mode"
Someone posted "elsewhere" that for running the 1/4 its best to use the predator "dyno mode" tune. can someone explain the difference betweem dyno mode vs 91 93 cai tunes?>??
Dyno mode isn't a tune, it's a setting. It turns off all the traction control and all that jazz. Basically the key trick using the Predator.
The nice thing about Dyno Mode is that it stays "on" even if you shut the car off, whereas you need to do the key trick each time you start the car.
I've wrecked three too many burnouts with the ESP totally on -- it's always Dyno Mode for me at the track.
The nice thing about Dyno Mode is that it stays "on" even if you shut the car off, whereas you need to do the key trick each time you start the car. I've wrecked three too many burnouts with the ESP totally on -- it's always Dyno Mode for me at the track.
I've not used it yet. Do you just leave the Predator hooked up or do you tell it dyno mode, unplug the Pred, then plug it back up to take off dyno mode? I think my Interceptor gauge can kill all the TC stuff through it with the push of a button. I need to test that too.
Cool Imma try that.
Oh, and doesn't look like "multiquote" works.
To multi-quote just hit multi quote on all the ones u want to quote and then hit Use Full Editor.
Sure it does...
Only the predator and a few other tricks i know of, can truly turn all of the traction and electronic stability stuff off, and it says off till you plug the predator back and and turn it back on, keeps the car ready to go all night at the track. :o
What they said. It's great for burnouts :( It's also pretty cool to leave on if you don't want big brother buggin' ya, but just remember you've unleashed the beast...
