legmaker
Lmi Headlight Cai
30 posts in this topic
This is something for the all out, hardcore, chasing every tenth kind of racer. Not for the daily driven car.....
LMI Headlight CAI
Pricing for HLCAI is $324.99 plus shipping (kit seen in picture below) and comes with:
- (1) 4" Straight CF tube
- (1) 4" 90* CF tube
- (1) 4" Silicon Coupler
- (1) 90* Silicon Coupler at throttle body (specify TB size)
- (4) High quality T-Bolt style clamps
*NOTE: HEADLIGHT NOT SUPPLIED!!!!!!
See this link for install tips - LMI Headlight CAI Install Guide
As an option, a Frank III kit (4" CF tube w/7" S&B filter) can be purchased as well to allow for driving to and from track.
Cost for HLCAI w/optional FIII add-on is $399.99 plus shipping
HLCAI Kit
This kit can be utilized on an LX/LC vehicle!
yeah i got that, i'd still be concerned about wind blowing dirt/sand debris across the track, or heaven forbid you are slower than the other guy and they kick up sand/rocks and you suck that crap in.
Maybe I'm just a worrier, I guess it's a risk to take to go fast
Yeah, you could suck in a bird or a small child too ! :huh:
These setups really work well ! Some of the best gains you can get for the money spent.
I could use one of Goehner's panty hoses to put over the end.
Worse comes to worse, just change your oil more frequently
Any sand, dust, dirt that might be picked up will just seep into the oil
Damn I got excited for a minute, thought you made me a custom filter to fit behind my light, lol
just stick it infront of the headlight and hope for now rain
I pulled my CAI off at the throttle body while on the dyno last fall and gained 30RWHP in back-to-back runs. I immediately decided I was going for a headlight CAI for the track.
If you don't have the IAT nanny turned off in your race tune, you will also benefit from lower IATs with the intake out from under the hood and up away from the asphalt.
From looking at my datalogs with the LMI true CAI (fender mount) vs. my headlight CAI, I deduced that the benefit is purely a matter of getting ambient air to the engine quicker (almost instant with the headlight CAI compared to about 1.5-2.0 seconds with the true/fender mount CAI).
this set up is for race only........ any one looking to run it on the street is lacking some brain cells
this set up will gain 2 tenths as jon pointed out
this set up gets ambient faster due to zero restriction from the filter, shorter distance to tb, and higher off the ground.
this set up is not for the faint at heart and requires some hand skills to cut the headlight correctly and cleanly
this set up is not designed to put goehner's panty hose on because they WILL get sucked in
this set up DOES induce boners, but please do not insert said boner into the headlight opening............LMI can not be held responsible for user error.....
any chance you could email me those logs jon????? [email protected]
Lmfao!!!
Here is the LMI True (fender mount) CAI.
Notice how long it takes for the intake air temp to drop as the car is making a pass (I could not fit the entire drop on the screen... there is nearly two seconds missing at the begining of the run).
And here is a pass with the headlight CAI. Intake air temp drops much quicker.
