KeavDog
Charger Build Under Way
159 posts in this topic
News that my track (Fontanta - ACS Dragway) is reopening next year prompted me to spend some $$ to go faster. My pb to date is 11.79 @ 8lbs of boost with the Maggie. Want to go faster!
Here's what Lonnie (whitehemi) and I have started
Inertia MotorSports 370CI all forged internals (Under way)
Inertia big valve heads
Inertia cam
Kennebell 3.6L Blower
Procharger F1A
HHP return fuel system
Kooks LT headers and catless mids
Modern Muscle stage 3 ported 6.1 intake
Paramount Transmission NAG1 conquerer
Paramount Dominator Torque Converter
Afco Mopar Dragpak shocks/springs
TCE wilwood 15" rear brake conversion
Spohn rear suspension kit
HHP Solid diff pinion bushing
Whiteline rear subframe front/rear bushings
Rollbar - manufacturer/install TBD
Josh tune.
Hope to be well into the 10s - and maybe see 9s
Good luck, You will love your Inertia motor I know I do mine. Stu's 370 and a 3.6 KB I see 9's in your future for sure. I was thinking about upgrading from the 2.8 to the 3.6 myself.
You should see 9's all day long. My 370 with the 2.8 kb runs consistent 10.0 -10.2 in the heat. 9.8-9.9 in good cool air. Nice to see someone playing with the 3.6 again . Others gave up too soon imo but that was the early years on this platform. TORQUE was the main factor. Getting all it puts out down on the track was always the issue. 15" conversion is your friend! lol
One more.02....STUD your heads!
Good Luck ...should be off the hook!
Thx all. Stating at 14 lbs. learn how to drive it and go from there.
That's great news! Arp studs on the build.
I wish I would have picked up gsos 15" brake kit....
Additionally Requirements and specifications for Street Legal are the same as those for the Summit Racing Series with the following exception: Unaltered 2008 OEM model year and newer production cars running slower than 9.99 and 135 mph do not have to meet the requirements and specifications for the Summit Racing Series except for the following: Convertibles and T-tops must meet Summit Racing Series Roll Bar and Roll Cage requirements, All drivers must meet the Summit Racing Series Helmet and Protective Clothing requirements.”
Link... http://www.nhra.com/userfiles/file/2012%20to%202013%20Rule%20Book%20Amendments.pdf
To be honest you should look into mani's stage 2 procharger. I'm sure he'll come down some. You'll be a lot happier in the long run. If you like I'll give you the ph to the guy who bought my procharger that ditched his KB. He'll tell you what the disadvantages are to the KB.
Also if you do go KB I would send it to cam first to do the independent drive mod. But your looking at not getting back for at least. 3 months.
