V3rbal
Spy Shot; Hemi Wipple
Spy Shot!
Coming soon…4.0 Wipple fits under-hood and still has 7.5” runners.
6 available for order now with billet manifold; cast manifold available in the spring.
(Prototype shown; expect some changes…check in here for updates)
You guys are really going to dig this intake when you get a look-see inside it. Joe the mad scientist came up with it and it's one of very few out there that will be able to make good use of all that Whipple flow. The runners are long and though there is a bend, it's not as bad as you might be picturing, plus some other improvements that will set it apart.
Big CCV system flow capability designed in to this as well, of course... :D
Plus, now is your chance to be the only guy on the block with a legit billet oil fill neck!!
ironchallenger - PM sent
Looks like a nice system to me.
Is there something that supports that long ass snout?
How does that 8 rib tension system work? It don't look like theres an adjustment on the pulley.
Have you guys run one yet?
How are the IAT's?
Can you post a pic of the heat exchanger?
